Window rollers
Andrew_r/t
California
The driver's side window on my 70 Challenger wouldn't roll up right anymore so I pulled the door panel off. I found one of the rollers on the vertical track in the front was broken. Is it possible to change them out with the window still in the door? It seems like I might be able to unscrew the roller part from the piece that slides in the track. Any recomendations on a source?
Righty Tighty
Sahuarita, AZ
I wish I could help. Instead, I'll be following along because I need to rebuild my windows as well. Hopefully somebody will chime in.
Andrew_r/t
California
Little update on this one. I was able to find some new rollers at fall fling this last weekend. After a while I figured out that I'd need to pull out the window to get the rollers in. During that process I turned the wrong nut and snapped the bolt on the part circled in the photo. Anyone know what this is called and where I can get one?
I also somehow managed to pull off the lock link rod and broke the little clip or plug that holds it on the lock lever mechanism. Hopefully there's something available for that as well.
