Windshield Wiper Switch
cuda426
My windshield wipers on my 1973 Barracuda went on without rotating the round on/off knob. I was able to turn them off so they were resting at the bottom of the windshield. But when I commenced to drive the car I noticed some smoke coming from the switch. I disconnected the wiring harness plug to the switch and the problem went away. Do you think I have a short across the switch?
Thanks, Bill
Is this a trick question?
From what you describe it appears so.
Swap in another switch and see what happens.
is there a method to check the switch with a continuity tester to determine if its defective or not?
thanks
Power for the wiper sw comes off of splice 3 that feeds the acc side of the fuse box, via the ign sw.
I would be taking a serious look at the firewall junction box and all of the wiring. They would have a difficult time turning themselves on by themselves via the switch. Sounds like something fed back through the switch wires (some of which go to ground via the switch case.
Please disconnect your battery!
I'm thinking it's the park switch malfunctioning. Drawing to much current when hanging up. 2 speed or 3?
Thank you, the wipers were in the parked position when the switch stared to smoke. Where is the park switch located?
Do have a 3488764 three speed switch. In the off position on the switch, test the impedance between the B and P terminals. That should read 0 Ohms. The second test is between F1 and the metal frame of the switch. That too should read 0 Ohms. If both of those tests read correctly, then test the impedance between the switch socket and the bulkhead connector:
Bulkhead position 1 - Switch Socket A (Brown w/ White Tracer)
Bulkhead position 2 - Switch Socket F1 (Red)
Bulkhead position 5 - Switch Socket P (Blue)
Bulkhead position 6 - Switch Socket F2 (Green)
Each of these reading should show 0 Ohms.
Found from a post over on cuda-challenger.com
Testing a 3-speed wiper system
The 3 speed wiper system controls the speed by use of a resister in the switch, not in the motor. The switch also reverses the current to the motor in the "off" position, which causes the motor to seek the "home" position. There is also a circuit breaker built into the switch to protect the circuitry.
Testing the switch
There is a test for the switch that can be done with a continuity tester or an ohmeter. To do this test, on the back of the switch, the terminals are marked with an "A", "B", "B/U", "F1", "F2", "P" and "R1". In the tests, "Ground" is the switch casing.
While in the "Off" position there should be continuity between
B to B/U
B/U to P
A to F2
F1 to Ground
"LOW"
B to B/U
B/U to A
A to F1
F2 to ground
P - open
"Medium"
B to B/U
B/U to A
A to R1
F2 to ground
P - open
"HIGH"
B to B/U
B/U to A
F2 to ground
P - open
Testing the motor
The motor only has two speeds, high and low. The medium speed is a variable speed, which is configured by the switch varying the voltage to the motor.
"Low"
Connect the motor housing and the green wire to ground
Bridge the brown and red wires
Connect either the brown or red wires to 12v
Motor should turn slowly
"High"
Connect the brown wire to 12v
Motor should turn fast
"Park"
Connect the motor housing and the red wire to ground
Bridge the brown and green wires
Connect the blue wire to 12v
Motor should turn backward, then stop in park position.
