Windshield Wiper Switch
cuda426
My windshield wipers on my 1973 Barracuda went on without rotating the round on/off knob. I was able to turn them off so they were resting at the bottom of the windshield. But when I commenced to drive the car I noticed some smoke coming from the switch. I disconnected the wiring harness plug to the switch and the problem went away. Do you think I have a short across the switch?
Thanks, Bill
is there a method to check the switch with a continuity tester to determine if its defective or not?
thanks
Power for the wiper sw comes off of splice 3 that feeds the acc side of the fuse box, via the ign sw.
I would be taking a serious look at the firewall junction box and all of the wiring. They would have a difficult time turning themselves on by themselves via the switch. Sounds like something fed back through the switch wires (some of which go to ground via the switch case.
Please disconnect your battery!
Thank you, the wipers were in the parked position when the switch stared to smoke. Where is the park switch located?
