Cudakiller70
- Joined
 - Aug 3, 2016
- Messages
 - 118
- Reaction score
 - 33
What I would do is get the model number and go to manufacturers site to verify what it has and how it’s built mine is 2 years old.Was looking at this again before I order it. Can you confirm the feed and return sizes? The amazon link doesn't list any. Really hoping its a 3/8" outlet/feed line
Going by memory my tank supply is 3/8.
Return is 5/16. Transitioned from 3/8 line to 5/16 right at the tank with fittings.
This car had a stock 5/16 fuel line, replaced with 2 3/8 from fine lines. One supply and other return.
This link is for Cuda
70-74 Plymouth Barracuda / Cuda; 3/8" Fuel Tank to Pump Line; Steel | eBay
One other thing you need to be aware of, Mentioned this above about the pump filter sock it is 180 degrees out if your buying the fuel tank and it comes with a sump pan. If your getting just the pump for stock tank it’s fine. But I think I would get the Holley hydro mat for low fuel starvation.
Look closely at the fuel sock it looks folded. Probably still works maybe not ideal.
