gzig5
Correct, the B body perches line up with no problems. The E body perches are 46 inches apart, and the B body is 44 inches. So, the offset is only 1 inch per side. Also, Cass from Doctor Diff told me that the pinion angle is different on the B verses the E, and I could use the top lowering hole to correct it, or use the angle wedge that he sells if I wanted to keep the stock height. The only thing I have to figure out is the rear shocks will not be standard length. Since the shock plates are moved in, and now lowered, it would bottom the shocks out quickly. It should be a simple measurement though. Here is a link to the kit I used.
Mopar '70-'74 E-Body Spring Relocation Kit Offset Hangers/Shackles
That is good to know about the pinion angle. Wasn't aware. I have a 66 B body waiting to get cleaned up and go in with the Dr Diff kit.
