MAC
I have the Fitech fuel system on my 72 440 challenger, couple days ago I had to replace the battery on the car so I had the kid at a name brand auto parts store install an optimum battery on the car, while I was inside paying for the battery the kid hooked the battery terminals up backwards causing my leads to start melting. Before I could get the terminals off the rubber melted off the positive wire running to the starter relay. Going forward I swapped the battery around to the correct position and hooked it up, now my fuel pump runs all the time whether the key is off or on it doesn't matter. I emailed Fitech and they told me I needed a new wiring harness going to the Fitech unit itself (ECU) is if I swap out the wiring will I need new seals gaskets o rings etc... when I open up the unit. Of course Fitech sent NO instructions or precautions needed to take before under going this procedure. Has anyone pulled a similar bone head stunt as this with a Fitech unit, any assistance would be greatly appreciated.....thanks
