Carb rebuild
wantonebadebody
Bought a good core for rebuild
Anyone suggest a rebuilder?
4732s i put a kit in it but bogs terrible
Scott Smith Harms
Is the accelerator pump squirting fuel .
Is the float level high enough ?
then there is some problem with the accelerator pump circuit either a bad pump seal or a blockage in the passage or squirter
the passage goes from the bottom of the pump up to the center of the carb where the squirter mounts , you may be able to run a thin piece of wire through it most of the way at least , compressed air will work well also .
wantonebadebody
i assume its the center hole under the squirter?
There is also a one-way valve at the bottom of the bowl
