Passing gear throw from under or over to carb?
wantonebadebody
I would call this from under
FSM for all V-8 except 426 Hemi. You have your rod flipped over.It installs from the other side.
  • THROTTLE ROD ADJUSTMENT 8 CYL SINGLE SECTION ROD.pdf
  • THROTTLE ROD ADJUSTMENT 8 CYL 3 SECTION ROD.pdf
challenger6pak
This is an Edelbock carb built with GM style linkage. It is not a Mopar AFB or AVS. It does not have holes to properly fit the Mopar kickdown linkage without the adapter.
oldkimmer
I agree, it needs the adaptor. Is that the right top kd rod? Kim
