Reverse light Issues
Lime Lite 70
Knapp, WI.
I replaced a oil pan without removing the motor remover the z bar and replaced it, reset the clutch free play started the motor everything worked fine. Then when and started it again the reverse light will not turn off when shifting. I installed a new reverse switch a few weeks ago and everything was fine until now. I have a 70 Cuda 833 trans I restored the car 7 years and have owned from new and never had a problem ever like this. any help would be great. Lime lite 70
Unplug single connection that comes out of firewall .see if it goes out. As
70chall440 said I think it's a bum switch.​
My rule of thumb is go back to what you touched last , is the wiring ok to the switch , , use an ohm meter & test the switch too .
Lime Lite 70
Knapp, WI.
Thanks I disconnected the wire and it went out. Then I pulled the switch and the detent ball was stuck all the way in so much for new and simple. Thanks for the thread return
Lime Lite 70
Knapp, WI.
thanks for your thoughts, I retraced and tested and unplug and removed a bad switch, and replaced it works like new now. Thanks for your thread
