Reverse light Issues
Lime Lite 70
Knapp, WI.
I replaced a oil pan without removing the motor remover the z bar and replaced it, reset the clutch free play started the motor everything worked fine. Then when and started it again the reverse light will not turn off when shifting. I installed a new reverse switch a few weeks ago and everything was fine until now. I have a 70 Cuda 833 trans I restored the car 7 years and have owned from new and never had a problem ever like this. any help would be great. Lime lite 70
Unplug single connection that comes out of firewall .see if it goes out. As
70chall440 said I think it's a bum switch.​
My rule of thumb is go back to what you touched last , is the wiring ok to the switch , , use an ohm meter & test the switch too .
thanks for your thoughts, I retraced and tested and unplug and removed a bad switch, and replaced it works like new now. Thanks for your thread
