So the car is not supposed to be level?No there isn't any marks, what you have to do is set the front where you want it and then adjust the rear up or down (usually down). The car will sit down in the back and slightly high in the front. You have to think about where the center of gravity is for the car.
Ok i got the cuda up on the rotisserie and both sides are the same height. When im turning the car on to its side it get very hard to do once i get about 3/4 of the way... And im afaird to turn it upside down. Should i raise or lower the car on the axis to get the center of gravity?No, it will be top heavy if it is level.
Raise the front end or lower the rear end a little at a time, try turning it after each adjustment. It should get slightly easier and over time you should be about to get it to where you can rotate it pretty easy. Just remember to keep it high enough so that the roof will clear your bottom center bar.Ok i got the cuda up on the rotisserie and both sides are the same height. When im turning the car on to its side it get very hard to do once i get about 3/4 of the way... And im afaird to turn it upside down. Should i raise or lower the car on the axis to get the center of gravity?
Will give it a try...Raise the front end or lower the rear end a little at a time, try turning it after each adjustment. It should get slightly easier and over time you should be about to get it to where you can rotate it pretty easy. Just remember to keep it high enough so that the roof will clear your bottom center bar.
If it's bottom heavy, there's too much below the centerline of the rotisserie. Like ballast on a ship. You're going to have to raise something up. I'd think the back end since there's more weight towards the back of the car but you'll need to "feel" it to be sure.
Thanks for all the help i got it balanced right and now i can flip it with ease!!!
Looks like you need to raise the back riser up further (where you see the roller). Front looks to be at least 2 or 3 holes higher than the rear.
