Both sides of my fuse panel are hot
340 Slapstick
St Louis Missouri
I was hooking up my stereo and found out that the accessory side my fuse panel is hot at all times no matter the position of the key. Both the Black wire side and the Red wire side.
I am in the process of restoring this 70 Gran Coupe and the under dash wiring was in such good shape (looks) so I decided not to spend the $700 for a new harness. I have started to look at all wiring under the dash but I hate to cut away all of the factory tape and covering on the original wiring Harness. Does anybody have an idea where to look for the most probable issue.?
under normal use it should run cool , could be corrosion in the firewall bulkhead plug or fuse contacts or the wires on the back of the fuse block .
Do you know if it was it always like that or it just happened?To start.Unplug your ignition switch.under steering column.Check to see if still hot. keep battery terminal off after testing. Click hear for reference pictures. Front and back of fuse box also.
340 Slapstick
St Louis Missouri
Yes by "hot" I meant 12v always. I will unplug the ign. switch even though it's new, and check.
I should also mention an issue I had before disassembly, which was, when shifting my column shifter from park to drive the starter would engage when going past the neutral position. WEIRD. now I am converting to console shifter. I HOPE it still doesn't do that with a new engine bay wiring harness and neutral safety switch wiring. Not an electrical minded guy so i need all the help I can in figuring this out.
Maybe something pinched in the column that's causing all the issues.Or melted together!
340 Slapstick
St Louis Missouri
well I took my column apart yesterday and didn't see anything. it still may be possible but not sure where it could be. I looked at all crossed wires and connections in the column and removed the blinker wiring. I may have a cheap ignition switch that went bad???
What's the problem?You ask.So you want to cut your jugular!"How difficult was it to replace the firewall bulkhead connector?" Remove seat would make it easier to start. unsnap fuse box.Remove the bulkhead screws.,remove one connector at a time,do one plug area to save some confusion, small tab on connector has to be depressed to release.Clean or replace and grease. Dielectric grease and copper-tin cleaner and connectors in hand before you start.And a little
Patience.​
340 Slapstick
St Louis Missouri
So I disconnected my ignition switch wiring from the rectangular connector and both sides are still “hot”. It looks like these wires run up to my ammeter. Is it possible my ammeter is bad?
Unclip the fuse box and look at the back see if there are wires crossed and shorted.
1:RED wire 16 Battery power yellow dot to splice one feeds fuse block, 2:charge wire 18 black wire blue dots to splice one through amp meter to red wire blue dot 16 to battery, 3:ACC feed from splice 1 Red wire Q3_12R yellow dot to steering column. Black wire 12BK red dot to ACC side of fuse box.
So if you find nothing.Thinking you have radio hooked up undo radio. radio has a power, acc,and a light circuit? could be feeding back through. may have to wire diffiently. Turn radio off.see if power batt or acc goes off.
I am sorry I didn't read your post well enough , something has to be back feeding the accessory side , bypassing the ammeter is always good advice , I just connect both wires to one side .
340 Slapstick
St Louis Missouri
Ok I figured out my problem!! I had the small light blue “connecting “ wire that has 2 pieces of light blue wire with 3 black push-on connectors on the ends, connected to the black side of the ammeter. Still haven’t figured out where that connector goes but at least my fuse panel is acting like it should. Thank you all for your help!
