Date code 727 will it fit?
340 Slapstick
St Louis Missouri
I have a 727 trans STAMPED PK3898866 5689 3003 will it fit my 69 date coded 340? the torque converter cover plate doesn't line up with the holes on my trans.
thanks for any light shed on this.:BangHead:
will go by the engine builder and see if the plate lines up with the holes on the back of my 340
340challconvert
Parsippany, NJ
Here is a sample on how to decode your transmission;
Transmission Part Nnumber
PK 3410668 L 3028 6361
PK = Kokomo transmission plant
3410668 = Part number = 1970 Year model A727 for a 383 CID V8 HP
3028 = Build date = November 11, 1969
6361 = Sequential serial number = 6,361st transmission built that day
340challconvert
Parsippany, NJ
PK= Kokomo trans plant
3898866 =
318/360.727. truck, long tail
Dodge truck; 76 318 & 360, B100-200
Plymouth Tr. 76 318/ 360
Ramcharger 76 318/ 360 4x2
Trail Duster 76 318 / 360 4 x 2
5689 = Build date
3003 = sequential serial number of transmissions built that day
340 Slapstick
St Louis Missouri
3898866 =
5689 = Build date
thank you,
So a '76 that fits a 318/360 should fit a 340 right?
340challconvert
Parsippany, NJ
One other consideration besides tail length will be the torque converter that is used with the trans.
A 69 340 engine will be internally balanced. Later 360s were externally balanced and required a specific balanced/weighted converter. Don't think you can use the truck converter?
340 Slapstick
St Louis Missouri
Yes I’m getting a new converter to go with the total rebuild of both 340 and 727. Being a 340 with a date code in 1969 i hope I’m good
