71 EBody steering column turn signal wire cover
skip69donzi
missouri
Hi folks! I need clarity with these under-column covers for the right cover for my steering column. I attached a photo with them on an e-body column. I’m informed the longer (green) one is correct for e body. I purchased the short blue one as advertised as e-body. I was told later it is a B body cover. I am seeking to find a correct E body cover if anyone has one to part with. Your insight and help is greatly appreciated as always folks!
skip69donzi
missouri
I have one now and measures about 9” which is consistent with the green one pictured here.
Steve340
New Zealand
I had a look at my car but you cannot really tell without pulling stuff apart.
The green one makes the most sense as it would protect/contain the wires all the way through the column mount/bracket.
skip69donzi
missouri
What my thinking is too. You can see the shorter blue one that is a bit short in both respects, doesn’t even reach the brace points for the brack to dash mount. Is the B Body steering column that much shorter in that area so it fits the same as the ebody only shorter? 🤷🏻‍♂️ just curious. But I did find a cover that is the right length and nearly over looked it as it was titled advertised as a B body column cover. I bought it as it was 9” long and now I’m all smiles 😊
Thanks for chiming in!
Steve340
New Zealand
Not sure about the B body steering column question.
I noted the "flared" end of the cover at the top goes inside the lower "ring" on the column.
sixpactogo
Eau Claire, Wisconsin
Looks like the green one is the correct for E body. It goes all the way to the bottom of the mounting bracket. Here are a couple pics of a column shifted 73 E body column I have.
skip69donzi
missouri
Yes, 👍🏼
perfect. Just as I thought. Sure appreciate your posting and showing for clarification!
