WTB Upper column
marks ebody
Rathdrum Idaho
Looking for a 1970 upper Bearing turn signal housing.
Please let me know what you have and I know they’re not cheap.
marks ebody
Rathdrum Idaho
Sixpactogo
it will work but unfortunately it’s not the same 71 through 74 where the turn signal switches is different. Curious, how much do you want for that column?
rkleein, You’re right they will work, but unfortunately they look different.
pictured below is a 84 lower lever (Push down to remove key )on a 71 column.
rklein71
Amarillo Texas
I converted my 71 auto column to a floor shift column using pickup pieces. The ignition lock was different, although not noticeable once installed. I was not aware of a difference with the key removal part. It is installed in my not stock BHG and looks right, so it will stay. Interesting info.
sixpactogo
Eau Claire, Wisconsin
Sixpactogo
Sixpactogo
Sixpactogo
PM sent
72 blue 400
i have a parts column not sure on year,can post some pics tonight
marks ebody
Rathdrum Idaho
Really interesting
cell 818.425.3967 if that’s easier
I believe I got two mirrors from you super nice thank you
EW1BH27
Canada
Correct me if I'm wrong but isn't the opening for the 4-way hazard button also smaller on the 1970 column because the actual plastic button is narrower.
marks ebody
Rathdrum Idaho
Yes,1970 was a one year turn signal switch. The four-way flasher button is narrower
Top of this thread is a picture of what I need.
marks ebody
Rathdrum Idaho
Jim Here is a picture please look at the four-way flashers
2950816
sorry about the photo being that way, but it was the only way I could get the number to show in photograph
