FOUND 1971 Plymouth Cuda Rally hood insert screws
Cuda340N96
Central Texas 76852
Looking for the mounting screws for the insert on Cuda Rally hoods. There are 2 screws in each insert and I need a total of 4. They are phillips type heads with a very slight taper . Thanks for the ad E bodies and community for your help.
I might as well post my picture here too. Good luck. If worse comes to worse you can always buy Tony's reproduced 1970 style. Those attach from the back with Palnuts so the scoops have to come off the hood.
1970 and 1971 are the same. The change for the inserts came in 1972 and continued to the end of production.
Well, respectfully lets agree to disagree. All my research to date showed that 1970 was a one year only.
There "might" have been some carry over to '71, Ma Mopar was notorious for stuff like that.
Cuda340N96, try putting a WTB add in because all the aftermarket ones I've seen have too big of heads. Hopefully someone has some good used ones
This is a quote from his other thread. Someone once suggested to put those in a drill press and file the heads down.
