Spark Plug Gap Question
340challconvert
Parsippany, NJ
Installed the Edelbrock Performer RPM aluminum heads #60179 designed for the 68-73 340 engines onto my newly rebuilt "close to stock" specs 1970 340 engine.
Engine was bored 30 over as a clean up with new pistons
Initial start will be with points ignition
Edelbrock recommends the use of Champion RC12YC spark plugs with these heads. No recommendation on spark plug gap.
Purchased the plugs; I was going to gap at the usual .035.
Any thoughts on this appreciated.
Phil
That's where I'd gap them at. No reason to go crazy with a larger gap and stock ignition. When my 70 Challenger was my daily driver and only car, I used to gap the at .034 because they open up about . 001 every 1000 miles or so.
1972 Plymouth Barracuda 340LA Roller Cam and lifters; stock electronic distributor, all stock electronic ignition on firewall. Not the orange one. Just started her yesterday and can't seem to get the motor to run smoothly. Just confirming my spark Plug call out and gap. Running Champion with a .035 Gap with no points electronic Distributor
Phil
.035 is just fine.
Found that out yesterday during initial engine run. I thought for sure I had a leaking head gasket, but when my buddy was pulling the header back off, it was apparent that the bolt holes were spewing anti-freeze!!!!
Ok didn't know where you where at. Went back and looked at you postings.
1 Did you prime the engine before brake in. If not how long did it run.
2 I would change the spark plugs or clean them up. Might of got wet with antifreeze of fouled. Antifreeze doesn't dry out all that well. Just for shits and giggle recheck the firing order. YEAH I know I did it 10 times before the 11th time it worked. I know we think we can't make a mistake. Also check the distributor cap for corrosion. When I put a new cap on mine it was running like a champ. The next spring when I fired it up running bad. Checked the cap and rotor there was white corrosion inside. cleaned it up and was fine.
18536572. Run an extra ground wire to the ECU box from the engine block. If all the above stuff, plus the ground wire, mentioned doesn't help, it could be a crappy ECU box!
Bigger Question is What coil are you using , Higher output coils you can open up to .40 with good 8 mm wires
