challenger wiper assembly question
ogre
orchard park New york
Is there a difference between years 70-74 for challengers wiper assemblies? I have a 70 Challenger which needs a variable speed motor but can I use the linkage under the cowl from a 72 challenger? Are they the same or is it a 70-71 and 72-74 like for the front fenders.
Ogre
yes 70 is unique from other years , 2 speed & 3 speed are different from each other in all years .
EW1BH27
Canada
For added info....
Steve340
New Zealand
The 72 - 74 wiper motor crank arm is also different.
It is smaller were it bolts to the motor and the pin length for the linkage arm is also slightly longer than 70-71.
strycker
moncton nb canada
Can you send the lenghth measurements in inches for the 71 as this may be my parking problem (wipers won't park)
Strycker, when the wipers don't park, it's usually because the switch in the dash isn't letting the motor run in reverse to actually park the wipers.
strycker
moncton nb canada
Am concentrating on the grounding as i had another switch which did the same thing as the original,so I picked up an nos switch at carlisle this year and all 3 switches are doing the same
