jsand
Getting ready to order butyl tape for my windshield install. Does anyone know which size to use? 1/4, 5/16, and 3/8 is available through Year One.
I recently installed AMD front and rear glass with 5/16” butyl and the trim fit well. I tested for leaks afterwards by blowing compressed air from the inside and spraying soapy water on the outside. Found a few small leaks where I had to squeeze more butyl in to stop the leaks. I recall that the back glass seemed a bit short height wise so I had to put the butyl at the bottom edge of the of the top channel to ensure it sealed, so test fit where possible and have rubber shims ready to keep the glass from dropping.I haven't used AMD glass personally but heard it was good quality and the same thickness as original.
5/16" butyl - flat both top/bottom ( shown in pic's )Use 5/16 butyl if you are using original glass or the same thickness. Be sure to us some Pinchweld primer for Butyl tape for best results.
Another thing to mention is how new is the rubber. One time I ordered from an Auto parts store, they found it in the back. Was not sticky - looking at the label it was couple years old.5/16" butyl - flat both top/bottom ( shown in pic's )
rounded on sides.
Not round type ( for the round will smash down too thin = 1/4" )
I would mock up glass with all clips in place using dry rubber spacers tacked on - to then snap chrome window trim in place checking for fitment. Some places you may have to add a Stretched piece of 1/4" to thin it with a hair blow dryer for certain areas.
I do Not use caulk sealants due to future removal is messy/difficult. ( another story with that... )
