Help with Vin Number
1moretoy
Bay Area
Hello all, can anyone help me identify if these stamps are legit. The only one I'm really questioning is the engine block stamp. It looks as though the last digit (3) was stamped twice. Other than that everything matches from what I can tell. I don't have the build tag on the fender as the car was painted and lost at some point from what I was told. Is there any way to check the history of the car? Carfax doesn't go that far back does it? How can I break down my vin to check the factory options?
Dash plate
Radiator support
Cowl
Trans
Engine Block
Am I missing anything else?
Yes, it's a numbers matching car and typical of LA to switch the "0" and "E" on the radiator support and cowl body stampings. And the double strike on the engine block is common because that high nickel cast iron is hard material! It's also helpful to have the door sticker that lists the VIN, but these were painted over/removed quite often on 50 year old cars.
1moretoy
Bay Area
Thanks for all the input. Unfortunately I started the hellcat swap before I even checked this out. The gentleman I purchased it from didnt know much about the car. The person he got it from had the car for almost 30 yrs I'm told. That being said I didn't think anything of it. Is it more valuable being a numbers matching? It's just a 318 with a slapstick 3spd.
I would keep the original 318 and transmission since you have them and stash them in the corner and build it how you want.
1moretoy
Bay Area
That's what I was thinking. Anyway to trace the actual history of the car or get a fender tag?
1moretoy
Bay Area
I have the door sticker too.
Personally, I think a good restomod Hellcat would be worth more than a numbers machining 318 car, but keep all the original drivetrain and documentation in place.
In my opinion, if you have the build sheet, a Fender Tag can be reproduced. Otherwise it's really difficult and sketchy.
JDMopar
Candler, NC - Myrtle Beach, SC
I wouldn't worry too much about the fender tag if it's going to be a restomod. LA cars rarely, if ever had build sheets left in them, so getting an accurate tag made would be dang near impossible. Maybe get one of those custom ones and make it "Hellcat Prototype" or something to that effect. I never put the fender tag back on my 71 Challenger convertible since it doesn't resemble how it came originally. I have thought about getting a custom fender tag that reads MYOFB....lol. A lot of people will look for the tag, and then grumble if it isn't there.
1moretoy
Bay Area
What are hellcat swapped E bodies selling for? I definitely don't see many of them.
I think there's one coming up for sale at the Mecum auction. Might be worth keeping an eye on.
Did you look for the broadcast sheet? I would say it is a good number. I have double bumped on things that are hard.
MoparCarGuy
Your VIN of JH23G0E114143 for an LA-built Challenger would ballpark your Scheduled Production Date (SPD) as late-October. SPD would be approximately A23 (October 23rd, 1969). Below are the closest fender tags to your VIN sequential number 114143 that I have in my collection of images. Others on this forum may have an LA tag closer to yours to assist in narrowing it down further.
We can assist with configuring a repro fender tag if by some miracle you find a Broadcast Sheet somewhere in the car's interior. Search inside the springs of the rear seatback, passenger seat backs, above your glovebox insert, and even under the carpet.
Your decision on whether it is worth it to go to the trouble of configuring and getting a repro fender tag made.
While broadcast sheets were rare in LA built cars, I see to remember that about 10% had them. Figures crossed for you.
