MoparCarGuy
- Joined
- Jun 28, 2020
- Messages
- 1,011
- Reaction score
- 960
I am looking at options to overdrive my 440 water pump. My existing pulley setup is the March Serpentine Kit 40550-8 in black powdercoat. This kit has been on my 440 for over 20 years. No cooling issues except in Florida. Go figure.
My idling temp creeps upwards to 210°F with a 195°F thermostat. I am using all factory cooling components except for a Speedmaster High Volume water pump. I had a Milodon water pump previously and had the same issue. It may be that Florida is just too hot and humid for the factory systems.
That being said, the crankshaft pulley diameter is 6" and so is the water pump pulley (fan pulley) which provides a 1:1 ratio.
The Factory Service Manual (FSM) shows a 1.4:1 crankshaft to fan ratio (see ☆ in FSM chart below) which would require changing one of the pulleys to get to 1.4:1 overdriven. My other factory components are in the green boxes. Usual stuff, shroud, 7-blade fan, etc.
Option: Keep the 6" crankshaft pulley and reduce the fan pulley to 4.25" to achieve 1.4:1 overdriven for the water pump.
The fan pulley drives the water pump AND the alternator so it may need to have a 6"/4.25" combo pulley to drive both pump & alternator correctly.
Does anyone know if March makes a 4.25" version of the dual, belt fan pulley?
