Remove #2 spark plug issue on 440?
Mikes72
Has anyone had this issue? If so, what was your solution?
On my 440, I don’t have enough clearance between the shock tower and the #2 spark plug to get a standard spark plug socket on the plug to remove it. Even if I could slide one on the plug I couldn’t back it out even a fraction before the socket gets snug up against the shock tower.
I’m considering cutting down a socket to fit and using a wrench to turn it. Before I do that do you guys have any other ideas?
Thanks, Mike.
Mike, the spark plug socket I have has six (6) flats on it like a nut. I've used a 3/4" wrench and just the socket before! If needed, I can provide pictures tomorrow of the socket and wrench. On big block E-Bodies and HP stock exhaust manifolds, I've had best luck changing spark plugs underneath the car! Here in the desert that's a plus on cold concrete!
DetMatt1
I use the box end of a combination wrench in place of the socket for those tight situations.
Mikes72
Sorry, maybe I didn’t explain my issue right. It’s not that I can’t get the socket handle on the socket once the spark plug socket is on the plug, I cannot get the spark plug socket on the #2 plug at all. The shock tower gets in the way no matter how I try to wiggle it around.
That’s why I’m thinking of cutting down the socket maybe a half inch so it can clear the shock tower and get on the plug. Then use a box wrench to remove the plug.
704406
Shawnigan Lake B C Canada
I use a snap on socket that is 2 3/8" long with the 3/4 hex on the end. loosen the plug with a box end wrench then remove the socket and spin the plug out by hand
DetMatt1 is correct you can just use a 13/16 boxed wrench to loosen the plug then spin it out by hand as well
pschlosser
Santa Rosa, California
Sometimes headers can make changing the plugs a complete nightmare.
But even on factory motors and exhaust manifolds, there can be a plug or two that takes some finesse and/or the right tool to be easy. I've even gone under the car to try and reach plugs from below.
440 E-bodies seem the tightest. Once, I had to remove the exhaust manifold to make room to get a plug out with the tools I had.
Certainly cut down a socket to make it work. But seems like something is up to specs. Maybe worn or broken motor mounts? The E-Body was designed to easily fit any Chrysler engine into it including obviously the Hemi. If you're dealing with an A-Body, I could definitely see an issue.
I just searched and found this wrench for $20 at Home Depot. It would get the plug out no problem. Probably what DetMatt1 is talking about!
Ricks72Chlgr440
Sisterdale, Texas
I have TTI headers and TF 240 heads with the angled plugs and the #2 is THE most difficult to get out, bar none. The header tube and the shock tower have teamed up to conspire against a plug change!
Mikes72
This looks like a great option. I'll track one down and try it out.
Steve340
New Zealand
The spanner in post #7 is an offset double ring spanner. I have one that I sawed the 7/8 end off.
It works fine to loosen or do the final tighten were there is not much room.
Buy a set of them they do come in really handy at times. They are good for intake manifold bolts.
Daves69
ChiWest
DetMatt1
That’s why I said don’t use a socket at all where you can’t, just use a box wrench. It’s so easy that while I have the box wrench in my hand for #2 I’ll do 4 & 6 so I don’t have to straighten up and change tools again. You can get those 3 loose with the box wrench from the top side by reaching under the alternator in a matter of 15 seconds and then just twist them out by hand.
challenger6pak
I've had this same issue. It was caused by a motor mount. It wasn't broken. It was worn, as in beat down or flat.
heminut
Deming, New Mexico
I've made special tools for this type of stuff through the years. I pick up odd wrenches and sockets at yard sales for exactly this purpose. A hacksaw, a grinder, a mig welder and some scrap metal and you're good to go!
I guess it rubbed off on my son too. He works on the electronics on F-16s at Davis-Monthan AFB in Tucson and has made a couple of special tools for his job.
Mikes72
Hey, thanks to everyone who posted ideas and stories. I was able to buy an offset double ring spanner like Steve340 identified and Xcudame suggested. It worked like a charm! In fact, I used it for #2 as well as #4 & #6 just like DetMatt1 posted.
I doubt I’ll need the tool often but it’s the ideal tool for this job.
Mike.
tonysrt
There are some box wrenches that don't have the steep angle with the one you showed. I have one that is almost flat, you might even try a ratcheting box and open end wrench.
fasjac
Yea, same here. 5/8’s and 3/4 wrench on the hex.
Easy with the aluminum heads and anti seize.
