I recently had to replace the lifters and pushrods in my AAR Cuda.
The original part numbers are:
lifter 3577092
pushrod 3577121 length 7.250 diameter 0.375
After a lot of research and searching, I ended up replacing them with lifter COMP Cams Pro Magnum Hydraulic Lifters 862-16 and pushrod Summit Racing Pushrods SUM-G6420 Overall Length 7.389 and Diameter 5/16 in (0.313).
I had no issue stetting the valve lash and it seems to run well.
Currently I have the carbs off, just had them restored by Harms. If I got it wrong, I am at a great spot to change them. Anybody have any comments on the parts that I used or any suggestions on alternate parts to use?
lifter 3577092
