Recommended timing 1972 Barracuda 360 w/ purple 509 cam
portland or
Here’s the specs of my ride. What would be optimal initial, total timing?
1972 Barracuda
360 Chrysler
Over bored 0.03
Kieth Black Pistons
Mopar Purple Cam 509
MDS Distributor (light blue & light silver springs w/ purple bushing: estimated 19-20* of total advance)
Headman ceramic headers
Manual valve body tranny conversion 3600
My main question is how does the cam either affect timing or would need timing changes?
Also does the manual valve conversion require timing adjustments or is that not affected but requires timing to be precise?
This is a car that I purchased from a guy at a great price because it was making a grinding noise on the front passenger wheel. I though bearing so when I took it apart I found the new brake pad was installed backwards. And this was done at a shop!!!! Anyways I’m going through the entire car by principle.
Thanks in advance.
I set it to 16* initial and total was very close to 35*/38* total but the rpm’s would really bog at 900-1100. Almost had to get it to 12000 rpm at idle. That’s gotta be too much right. Maybe this is just a carb tuning thing or maybe my timing values aren’t correct for the installed pistons, cam, etc..
IMO 16* initial is about right , although total timing is far more important than Idle timing .
I always time by ear to see what the motor wants , bring the RPM up to 2500 plus & you can hear the difference as the rpm rises until it stops a flattens out , I usually set timing just before it starts to level out .
I suspect it is more of a carb tuning problem
portland or
Ive been leaving off the air cleaner off. So I found a carb bolt washer(hard plastic) had split so I’ve replaced it with a aluminum one and now gonna see how it likes it.
Mr Cuda
North of Seattle
Got to know what the compression ratio is, or at very least, the cylinder pressure.
A 509 cam in a std 360 with 8.2 CR is not going to run well.
There are fixed spec for every build. Vary from that and it wont work as it should or as you think it should. The fixed selected specs or parameters being carb,intake,head,valves,crank and pistons and cam. The cam being the heart rate of the engine is how it will breath. Yes the crank can be of a different design, stroke and crank layout. But that is a whole other thing.
They way to consider this is if you are selling apples sell apples. If you selling oranges sell oranges. I not then you just end up with fruit salad.
There members here that are very knowledgeable about this. Use it to you benefit.
Ricks72Chlgr440
Sisterdale, Texas
1972 Barracuda
360 Chrysler
Over bored 0.03
Kieth Black Pistons
Thanks in advance.
View attachment 131665View attachment 131666View attachment 131667
Does your distributor have vacuum advance? If so, is it connected to full manifold or ported vacuum? Bogging at lower speeds means the engine is not making enough power to be happy. This is especially true if you have heavy electrical loads calling for power (i.e. electric fan, A/C compressor). You likely need a bit more initial timing but you don't want to go over 36* or so on top. The MSD distributor uses a small bushing to limit total advance. You likely need to change that. By the way, I had a 440 that I could not get enough low end power to not want to stall when the A/C and electric fans came on. Engine had issues so I took it to the machine shop. Found the guy who built it did not degree the cam properly. The cam needed to be advanced 6* to get to the spec on the cam card. That really woke the engine up. I also installed the progression ignition setup so I could tune the timing from my phone. Big difference. Just FYI.
Mr Cuda
North of Seattle
Ok. You have compression. Big cam, low compression was my first thought. It's a common mistake.
Make sure the primary throttle plate is not open past the transfer slot. It might take some tweaking to get the rear plate cracked open to get proper idle speed, with the primary plate in the correct spot. (Unless its a holley, then its easy)
You need idle control to get off idle response and prevent it from going flat at low speed.
I wouldn't break a new engine in with ceramic coatings. The coating will likely burn off!
Did you actually calculate the compression ratio with the KB pistons and the cylinder head combustion chamber and gasket thickness? Are you running KB190s (popup piston)? Unless you're running aluminum heads, 10.9:1 with cast iron heads will require higher than 93 octane.
Did you check valve to piston clearance?
Distributor have vacuum advance too? I normally leave that disconnected at break in because you want to run the engine at approximately 3000 rpm for roughly 20 minutes. Fine tuning comes after break in. What size and make carburator are you running?
Assuming that you did all the due diligence of engine design and everything is working together as it's supposed to be, 16° initial is a good starting point. It's hard to tell from your post if you already broke the engine in or not. If you did, I bet the header coating is toast!
I spend literally years designing an engine prior to buying one part. Even using a tried and true build that I've built before, I double check everything to ensure a known baseline.
TIMINATOR
Avondale,AZ.
Open chamber heads, a taller deck clearance, nonprojected tip sparkplugs, and thicker head gaskets require more timing than an optimized, tight quench area with a projected plug.
Aluminum heads require more timing than iron heads due to them transferring more combustion heat into the water jackets. A properly curved distributor requires less initial timing due to the quicker timing curve advance at higher RPM.
An abnormally lean or rich mixture requires more timing due to flame propagation.
Without more info, any opinions will only be a guess.
TIMINATOR
portland or
It is a Holley. I squared the transfer slot in the primaries as well as the secondaries. I’m almost thinking of closing the primaries and drilling some holes in the blades and just closing the transfer slot? I’ve seen that as a recommendation. What would the advantage of that be?
Mr Cuda
North of Seattle
Do not drill the plates. You can get the extra airflow for idle speed by cracking the rear plates. There is a tiny set screw to adjust them.
If you drill the primary plates to get more air (and speed) the extra air will mess with the idle mixure fine tuning.
You are not the first to need to tweak the rear plate, to get speed.
Make sure you have no distributor advance at your likely 900rpm idle.
Double check your current jet size with the carb list # spec. Just to be sure and have a baseline. Todays gas and that cam, start maybe 2 jets up.
Accelerator pump adjustment, and squirter is important for off idle response also. Amazing how often it is incorrect.
What carb do you have?
TIMINATOR
Avondale,AZ.
Do not open the secondary plates for a better idle. That causes a richer idle due to the secondary transfer slots being more open.
It also causes a small "flat spot" when opening the secondaries due to less fuel being available as the blades just open. The slots are there to provide a small amount of additional fuel into the airstream before the accelerator pump shot reaches the airflow.
Small holes drilled in the primary blades allow for more airflow without using up the available "slot fuel" flow.
Adding the holes is usually only needed when the cam duration is around 230-235 degrees at .050".
Start with a .060" hole in both the primary blades, with a longer duration at .050" you may need up to .100"-.125" hole. Start small and adjust the speed and mixture with the engine at operating temp. Then remove the carb and look at the transfer slots. With everything correct, the slot will appear "square". If the slot is longer on the manifold side, drill about .010" larger and reset everything.
Ram Air Pontiacs (cam was about 234°@ .050) had .085" holes in the Quadrajet carbs primary blades from the factory.
TIMINATOR
