7DCUDA383A
Is there a steel fuel line that is made to go from the fuel pump to filter to carb already fabricated to fit , for a 383 w/mech pump and a AVS2 carb .
So is the smaller tube from the pump to filter and the larger tube filter to carb .
YesSo is the smaller tube from the pump to filter and the larger tube filter to carb .
I just realized I ordered the Carter M4589 with push on lines .
Oops, sorry I miss spoke. I meant the other way around like 340challconvert said.
I guess the Carter for a 383 have push in hose connectors , can I take out the 5/16 hose lines and replace with 3/8 line without any reducing fittings , will the 3/8 hose fit on the Carter push on .Oops, sorry I miss spoke. I meant the other way around like 340challconvert said.
I'm thinking about do the lines myself , but never did that , I do wish I could do all the work myself, just don't have Graveyards tools .You can use that fuel pump. All are made in China these days unforntuately.I would run as much steel line as possible and use shirt rubber lines to connect everything up. Personally, I like to bend my own lines, but that's because I bent small tubing for a couple years.
