Any one use heat sheath
7DCUDA383A
60 Miles West of STL
Since I have rubber hoses from fuel pump to carb was looking at heat sheathing , anyone use this and is it worth it , also what power steering fluid y'all use , thanks for any info .
I've used heat sheathing on spark plug wires with headers. I think it helps.
If it's a Saginaw pump, Prestone power steering fluid at Walmart. If TRW or Federal, those use transmission fluid if I remember correctly.
Surfcuda
Palmdale Ca
Used it on fuel lines near the motor to prevent Vapor Lock problems I experienced. The heat sheathing was rated at 2000 degrees and kept the fuel line from heating up.
Mopar Nut
Engine Masters had an episode on this, they said it didn’t help at all.
I would think it has to provide some heat protection. Maybe not enough in some situations, but even aluminum tape will reflect some heat from surfaces.
7DCUDA383A
