Any one use heat sheath
7DCUDA383A
60 Miles West of STL
Since I have rubber hoses from fuel pump to carb was looking at heat sheathing , anyone use this and is it worth it , also what power steering fluid y'all use , thanks for any info .
I've used heat sheathing on spark plug wires with headers. I think it helps.
If it's a Saginaw pump, Prestone power steering fluid at Walmart. If TRW or Federal, those use transmission fluid if I remember correctly.
Used it on fuel lines near the motor to prevent Vapor Lock problems I experienced. The heat sheathing was rated at 2000 degrees and kept the fuel line from heating up.
I would think it has to provide some heat protection. Maybe not enough in some situations, but even aluminum tape will reflect some heat from surfaces.
