Valley and intake manifold installation.
6 pack
New Jersey, United States of America
Replacing 440 sixpack valley pan and Edelbrock aluminum intake on an original engine. I noticed when dissembling that the previous owner had used 4 gaskets. question is would it be necessary to use 4 gaskets again or can i just use sealant on the bottom of the valley pan? And gaskets between the valley pan and aluminum intake manifold. I was thinking that the previous installer might have used 4 gaskets because of leaks in the past. Can anyone recommend a good sealant?
I use 2 gaskets but I put them below the valley pan to seal Where the oil can be a problem .
You want a sealer That is fuel resistant , Right Stuff is great but not cheap
pschlosser
Santa Rosa, California
Could they have used four (presuming OEM-style one-piece stamped-steel) gaskets to resolve some kind of clearance problem? As if the mating surfaces between the intake and head were not quite coming together properly?
I've replaced a few of those one-piece valley-pan (intake manifold) gaskets on 440-4 and 440-6 when I had to pull one or more of the heads. I've even reused some of the intake manifold gaskets. I'm talking about the one-piece stamped-steel type. On both stamped-steel head gaskets and intake manifold gaskets, after a good cleaning, wiping the surfaces down with acetone, the only "sealer" I've ever used is that copper spray stuff (I think Permatex has a product). The product seals the more minor imperfections, such as pitting or micro abrasions.
But when you start talking about "The Right Stuff" I'm thinking of their really great RTV Sealant product, and that isn't something I would normally use on well-matched well-mating intake to head surfaces.
@Chryco Psycho seems to know his stuff, so maybe I'm missing something obvious, here.
DetMatt1
I mostly build stock engines for myself so cast iron heads and intake which means just the stamped steel pan. I just fired up a fresh 440 I assembled with cast iron heads and an aluminum intake yesterday. I thought I might need to use the fiber gaskets but when I did a test fit it became apparent that there was not room for any of the fiber gaskets and it sealed just fine.
i_taz
Pocono's PA
I have nothing but trbl with the valley pan but the biggest problem is oil wicking up the bolts.
As far as the gaskets, the factory didn't use any and even 1 makes it impossible to get the bolts started.
A 1/64th gasket from Hughes did fit but didn't do much to stop the seepage. Project Farm on youtube did a RTV test and the winner was the Mopar part # 04883971AC for oil and fuel resistance...
Use water pipe dope or blue loctite for the bolts. If there's no machining mismatch like Pschlosser is alluding to, I use the steel valley gasket with black RTV on both sides of the intake ports and the four corners. Haven't had a leak on various cars in over 40 years on wrenching. 🙂
MoparCarGuy
This video has some great tips on installing the big-block intake manifold correctly.
