Are there any disadvantages to switching to a single wire alternator? I have to replace my voltage regulator and was thinking of replace both the regulator and the alternator. Is there one brand alternator that is better than others? Thanks
Have you had any problems?I have been using a Powermaster one wire alternator for a few years. If I remember correctly I bought the 95 Amp--part 75191 I think.
I went to 1 wire when I converted to a serpentine setup. It is a 100a chrysler style unit from cvfracing. Works great. Just be sure to have the correct gauge wire (ie 6 gauge) going to the battery since the OE wire is too small.Are there any disadvantages to switching to a single wire alternator? I have to replace my voltage regulator and was thinking of replace both the regulator and the alternator. Is there one brand alternator that is better than others? Thanks
Nope.Have you had any problems?
Thanks. That's good to know.I went to 1 wire when I converted to a serpentine setup. It is a 100a chrysler style unit from cvfracing. Works great. Just be sure to have the correct gauge wire (ie 6 gauge) going to the battery since the OE wire is too small.
Thanks for the info.I bought a much more powerful single wire from Summit and love it. If you're not worried about looking original, I think it's a much better setup. I also did a Painless wiring harness so there's no old wiring in the car to worry about catching fire either. Run a bigger wire than you think you need.
