AAR 3x2 setup question
B5blueGC
MD
I purchased an AAR that was missing the original engine. A T/A block is a bit out of my price range. I have the original carbs but no intake.
I was hoping to get a good 340 block and some J or O heads and sit the 6 pack setup on it. Is there anything special that I need to know? Are the ports different?
Thanks in advance.
floyd
no differences between 340 heads and AAR heads other than the offset pushrod holes and rocker assemblies on the AAR heads. Ports are the same and you won’t have any issues adding a sixpack
Locomotion
Florida
Yea, T/A/AAR heads are just early OEM 915 castings that had the intake pushrod holes for its 2.02" intake valves machined offset .
B5blueGC
MD
Thank you.
marksmopars
The offset pushrod allows the ridge that exists top to bottom on the 340 intake port, allowing pushrod to operate, to be removed as it isn’t needed. The factory casting was the same, the machining of the pushrod offset to allow porting is the difference. Offset rocker arms are needed to accomplish the improved airflow potential.
Cuda Hunter
high mountains Colorado
So a regular block and heads will work fine with a 6 pack set up.
But, it will not perform as well as offset heads ?
Is this a major difference or minor difference in performance?
All of the differences with the T/A parts offer more potential for power without actually increasing it .
B5blueGC
MD
So unless you do the porting it won't make a difference is what I am hearing.....probably the way I will go since it is not numbers matching and T/A stuff is outrageously priced.
marksmopars
The advantage offered by t/a heads only is available if 5th are ported. If you look at your 340 intake port there is a ridge on the pushrod side that provides clearance for the pushrod. The t/a head moves the pushrod so the ridge can be removed.
Oregon AAR
Oregon
I have recently been down a similar road. My AAR came with a (non-matching) 340 T/A block. But with "X" heads. Instead of the correct AAR T/A heads. I found a set of the correct heads. They were advertised as "ready to bolt on". But without the rocker arm assemblies. They ended up needing to be completely re-machined. And I still had to come up with the rocker arms. In the end, they cost as much as a rebuilt engine would have.
If you are just going for looks, a non-AAR T/A "J" head, without the offset rockers, would do the trick. Also as an alternative, a set of nice aluminum heads, painted orange would even be better. Just my opinion. Good luck with your build!
Tetraethyl
Tennessee
Does anyone in this discussion have a set of 3x2 carbs for a small block, a/t they would be looking to sell?
Oregon AAR
Oregon
marksmopars
I have a set but the butterfly shafts are worn and need to be bushed, lots of work which is why I bought new.
