flamesoldier
I have no brake pedal lights. I have turn signal in the front and rear along with running lights. I have power to the brake switch and power from the switch with pedal applied to the white wire feed to column connector if i disconnect the pin connector to column. If i reconnect it i Have no power on white when i apply brakes. I also have no hazards with button pulled to apply hazards. I was told could be a bad signal switch?
