Strip or Blast or Sand Advice
zslacker
Castaic Ca 91384
My 70 Barracuda came with the dreaded painted black engine compartment, it was originally FC7. I'm no painter so I'll need to find someone who knows what their doing to paint it the proper color but before that I need advice on how to prep it. The rest of the car has very good paint and the glass is also very good so I want that protected. The business I spoke to about dustless blasting said the car would be fine and only the engine compartment would be affected. Am I better off sanding or stripping the engine compartment or using the dustless blaster? I would like the engine compartment to look as original as possible.
When sandblating it goes everywhere. A lot will end up in the cowl. If that's all that all that's being done I would use a stripper and wire wheel.
gzig5
Mequon, WI
The black looks like it was applied properly and isn't flaking off? I'd just scuff it, knock off any suspect areas down to the original purple, then prime and paint it. No way would I sand blast and dustless is not dustless. You end up with the paint that was removed as dust all over.
zslacker
Castaic Ca 91384
I sanded a bit more and the black looks like it was properly applied and i will sand smooth. Thats the route I'll go
1972 AAR Cuda
Washington state
Mine wasn't black, but I wanted to clean it up, so I took the do it yourself (rattlecan) approach. I clean it thoroughly, sanded and primed the surfaces before applying auto paint store mixed color and clear coat. Ten years later and it still looks pretty good. It's held up good. Surface prep (clean, clean, sand sort of thing) is the important part. The paint match can also be an issue - more of an issue with matching the exterior fade on mine than anything...
zslacker
Castaic Ca 91384
View attachment 141289View attachment 141290View attachment 141291View attachment 141292
That looks great. I spent stupid money on a different engine so if I can get it to look this good for a couple hundred that will make my day. How did you apply the clear coat?
zslacker
Castaic Ca 91384
I dig those old school cal custom valve covers too!
1972 AAR Cuda
Washington state
The clear coat was a paint store rattle can as well, I sprayed it after the base coat kicked off - basically like it was another coat of color only on the heavy side. The idea was to get it to lay as smooth as possible without runs or dry patches.
I ended up using factory steel valve covers due to clearance issue on the roller rockers... The aluminum looked good though.
6PKRTSE
As mentioned above. I welded in all of the factory holes not being used and painted the snout bars from my roll cage. I just scuffed my engine bay. We sealed, epoxy primed, painted and cleared by re-mixing the same B5 blue from when the car was initially painted.
