Rocker panel body plugs?
Charlie71rt
Do the holes in the rear inner rocker panel get a body plug? If so what type,
plastic cup type or rubber?
No plugs were used in that area. Nothing saying you can't put them in. Check the hole for size that you want to fill. There are a look of different sizes 3/4" Flush Mount Black Plastic Body and Sheet Metal Hole Plugs Qty 25 0.75 Inch |
Click here more on ebay.
[/URL]
Thanks for the input, not sure we are talking about the same hole if you are referencing the hole in the torsion bar cross member in your photo, I am referring to the inner rocker.
When I was working on mine underneath. I used sign post. They come in 3 different sizes slide in each other. So if your driving down a road and bunch of sings are gone. I was there.
I was replacing a lot of signs on the Interstate highways. Took them home and knew I was going to use them for something.
sorry I can’t take credit that’s just a reference photo from the web
There where no plugs in that area. At lest that I never seen. I'm just saying you can put them in to keep it closed off.
There is a chance of something climbing in there and making a home. I was checking someone's challenger at an alignment shop and found this.
