'70 Vert - waited long enough...
Here's the 0 body line. As I was saying . The top of the rockers just might be 0 body line. It would be a good refence.
Here's the 0 body line. As I was saying . The top of the rockers just might be 0 body line. It would be a good refence.View attachment 150168
I always wondered how to read that diagram and that makes sense.
Looks like the rear shackle mounts are 8" above the "0" line (rocker) which is then 6.2" above the bottom of the frame rail for a 14.2 total, then with my 6.25" datum line, my shackle mounts "should" be 20.45" above the datum.
I was going to say to build a jig. Silly me! I looked back and seen what you did.🤣 The other measurements I post. You can lay a level or straight edge across the jig and measure. I'll post some now and later.
I'm curious about the measurements across the top of the tail light panel. Looks like the center is 3/8' _lower_ than end ends? Am I reading that right?
Here again. There would be 3 1/2 " of the back measurements. Being it was zeroed on the top of the head unit on the bottom of the frame rail. All the one's I sent at this point are from that bench mark.
Fantastic. Taking your measurements and combining them with the drawing you posted, it all makes sense!
Now I can with confidence put the height of the rear, where it "should" be and verify everything is lined up.
Thanks again!
Corey
