FOR SALE Rare DC "Blank" ALL Aluminum 4-Speed (A833) – 2.66 Gears – Hemi Retainer
rbjorklu
Chandler AZ
Offering a rare Direct Connection (DC) racing ALL aluminum 4-speed survivor that has been in Arizona dry storage since 1982 . This is a "blank" casting, meaning no casting numbers, identifying it as an off-highway/performance parts unit rather than an assembly-line box. Main case is aluminum, side cover is aluminum, and short tailshaft is aluminum. Presented in its 1970s period correct dirt, grease, and patina.
Technical Specs & Machinist Notes:
  • Case Type: Reinforced DC Aluminum "Blank" with Steel-Bushed Countershaft Bore.
  • Gear Set: 23 spline input, verified 2.66 Close-Ratio gears with internal 34-24-34 blueprint marks stamped on vin pad.
  • Tailshaft: Short-tail (A-Body length) with the rear shifter mounting pad, 30 spline output and plugged speedo.
  • Internals: High-spec bronze shift forks and a 4.80" cast iron Hemi bearing retainer.
  • Extras: Includes the original 1970 Small Block Aluminum Bell Housing and Hurst mounting plate/welded shift rods.
Provenance:Acquired in 1982; custom-stamped "CLIFF K (Cliff Knight Inc., Livonia Michigan) 021 34 24 34" on the VIN pad on the case, originating from the Detroit-area Mopar performance scene. Side cover is currently off for inspection of the gears and bronze forks.
Price: $4,850 OBO Location: Chandler, AZ. Inspections are welcomed and Local pickup preferred.
I was asked on the FABO forums about the number of splines. Input shaft is 23 splines, tailshaft is 30 spline. I also found a reference and PN in my Direct Connection Racing Manual. This shows it for "special applications" with 308 bearing and steel counter-shaft bushing. While it does have the 4.8" bearing retainer, I have not verified the bearing size yet. Also as I have stated, I cannot find casting numbers or P/N numbers anywhere on the case, tailshaft, or side cover.
