727 reverting back to stock
tullm
Herndon VA
The original transmission in my car was switched to a reverse manual valve body. I'd like to revert back to stock. What is typically involved when changing to a reverse manual valve body? Is it only a valve body swap and removal of kickdown linkage? I see references in the rebuild kit descriptions for partial vs. full kickdown. Which style would have been original?
Thank you
M.
the mods converting the automatic transmission to a reverse valve body are not trivial. not only is the valve body modified, but a few other areas of the transmission are also altered. If you were already skilled at rebuilding the 727 transmission, I suspect you would find reversing the changes, and locating the missing and unaltered parts a real challenge and costly.
if it were me, I would seek out another used 727 transmission, and begin preparing that one for use in the car.
I don't believe the case, itself, is altered by these modifications. if the numbers on the first case are "numbers matching" to your car, and your car is a valuable optioned car, then you're faced with moving the guts from the other transmission back into your numbers-matching case. Also not an easy task, but easier than undoing the reverse valve body mods. especially if the transmissions are from similar applications and/or part numbers.
even if you have deep pockets, and insist on reversing the changes, it may be a challenge to find a shop that has the experience to make the repairs.
if you need to source parts, and get answers and specific technical support, I can recommend A&A Transmission. They have always had my back, and provided the parts and guidance I needed to get the job done.
Home - A&A Transmissions
That said, teaching one how and what to do, over the phone, is probably beyond the scope of the services they offer.
If you DO want to move the guts from one case to the other, go find the part number on the oil pan lip (PK-number) of your current transmission to help guide you in selecting the second transmission. The PK-number will also help you determine if the trans you have now is the original numbers matching.
For example, if your transmission is from a 1973 car, and you pick up a 1967 transmission from a swap meet, you're gonna have some challenges in a few areas. but if by some miracle, you find another transmission with the same PK-number, it may become trivial moving the guts into the original case.
Thank you @pschlosser. Although it's not what I really wanted to hear I at least have an idea of what's ahead of me. Ugh! The "PK" number is PK3410672L 29 [that's all I can see at the moment]. Theirs also a large casting number visible from the engine bay by the firewall, it looks like 176-7? The vin stamp matches the car ... so it looks like I'll have to go the expensive route. I'll reach out to A&A and 727Specialist
Thanks again
Since you're dealing with a valuable transmission that is numbers matching, you need to find out if other modifications were made such as sometimes the governor weights (inside the tail housing) are removed with reverse valve bodies. If you still have the governor weights, it's pretty much just a swap to a normal valve body and add back the three piece kickdown linkage. A part throttle detent valve assembly can be added (it wasn't original to your transmission) and is a nice feature to have.
Me, I would get a stock valve body and a shift improver kit and install all the parts needed with the kit (front and rear servo springs may have been changed for the reverse valve body and the accumulator may have been modified).
I highly recommend Tom Hand's Chrysler Torqueflite A-904 & A-727 Transmissions How to Rebuild book! It's a great book to learn Torqueflites and a great reference when you're an experienced rebuilder.
Thank you for your helpful post. I do have the book you referenced on my list of things to order. I don't want to fool myself but rebuilding a stock 727 doesn't look crazy difficult. I'll find out once I start disassembling the car. One of the hurdles I'm sure I'll have to cross will be how to tell a modified part from a stock one.
You're previous post referenced: "part throttle detent valve assembly", question: what would I notice or feel different as the driver of a car with said feature? I hate to sound ignorant but why should I stop now ... LOL
Thanks again for the help
M.
With that book, the proper tools and a little bit of common sense, the 727 is pretty easy to rebuild. I like to get a simple Pioneer rebuilt kit with seals, rings and gaskets and buy my clutches and steels from A&A.
Picture this, you're cruising along about 30 mph and somebody in a (name the car you hate) goes ripping buy you! You mash your gas pedal at it takes awhile for your stock transmission to get going even with your 440! With the part throttle kickdown valve, when you mash the pedal at 30 mph, it kinks down into second and you take off like a scalded monkey and blow past the yahoo! 🙂 What's not to like!
