MAX WEDGE INTAKE QUESTIONS
TIMINATOR
Avondale,AZ.
Thinking about running g a Max Wedge crossram on my new 512 build.
Now my questions:
What horsepower and torque differences would I expect over a big, modern, single plane intake with a 1250 or bigger Dominator carb.
Are there any out there for sale and for how much?
I have read that the earlier ones were prone to cracking around the bolt holes. True or ?
If there are some cracks there, are the cracks repairable and where should I inspect for them?
What are these intakes worth un modified?
I have seen one that has been polished "back in the day" by what I could only categorize as a moron, that ground off all of the casting and date code numbers.
So lastly, what is a serviceable unmodified intake worth?
Depending on the price, what would the polished, no numbers intake be worth and is it worth chasing down?
My car is a 72 Challenger, 512, 727 with a brake, relocated Super Stock springs, Max Wedge ported aluminum heads, TTI step headers, dual 3" exhaust, 4.10 gears, drag radials, solid roller cam approximately 270 @ .050, high 600 lift, (haven't ordered it yet), and I have 5 convertors
from 2500 to 5200 stall on the shelf.
Limited street and once a month or so track use and it better haul a☆☆!
Has anyone actually compared the Max Wedge intake to modern big single planes on the dyno or track?
I have my opinions, but no firm data.
I have several Dominators and a Super Victor, so is the Max Wedge intake gonna actually run faster, or just have it for cool points?
I haven't even heard of anyone having the linkage for a Max Wedge deal either, but I can fab it in my shop if I find an intake.
THANKS FOR ANY INFO!!!
Looking for hi 9s on the motor, and will prolly see what it will run with a plate (or two) system if my huevos hold up!
TIMINATOR
@TIMINATOR , A&A transmissions (yes, that's correct) used to fabricate the Max Wedge crossram intake. I believe they still sale a lot of the bits and pieces. Certainly the Max Wedge intake would have it for the "cool" factor. And the intake did help with the supercharging effect above 5,500 rpm. Which is between your planned maximum torque and horsepower range
To this day, I firmly believe the Max Wedge engines made more horsepower than Chrysler admitted to. But the Ramchargers pretty much abandoned them once the Hemi was built in '64 with good reason.
I have no first hand experience with an actual Max Wedge (or 426 Hemi). Too rich for me as I opted to retire early and enjoy life sooner. But in my humble opinion with what I have worked with successfully over the years, I think other than the "cool" factor, you'd be better off with the aforementioned single plain highrise intake and big four barrel. They have served me well. With the crossram, you're seriously looking at $3500 to $4000 for the setup and I'm not convinced you'd make any more horsepower. Certainly not enough to offset the cost to benefit ratio.
But I see your intrigue and love your thinking, it sure would look very COOL! I'm eagerly waiting other racer's opinions! 😀
I think the stock heads were the bottle neck that limited the outer limits. I remember drooling over the both 426's in the magazines in skool I mean school. While the girls where competing for attention. They lost to the magazines.
Here again to rich for my blood at the time. I'm not an expert on any of the above, 426's or women!!!!
Timinator is modifying the heads, so I see his interest in the Max Wedge Crossram . While it would look pretty awesome, I'm still not sure it's worth it. Hoping other racers will chime in soon!
Me and my flowbench put the 440 ports bottleneck at the flange.
Look at a 360/340, or small block chevy, the port opening at the flange is the same size!
Look at the Speedmaster catalogue flow #s for the smallblock Ford, chebbie, mopar, and 440 heads, despite the 440s intake valve that is near a quarter inch larger, the flow #s are nearly the same.
BUT they put a lot of metal around the port to open them up to nearly max wedge size!
I have ported stock 440 irons, saw the gains, then raised and widened the ports as much as practical and saw serious gains. Aftermarket aluminum manifolds typically have enough extra metal on the top to raise them to what the port new opening is.
I will post the bowl ported #s and then the Max Wedge port flow#s.
I asked Speedmaster why the Max Wedge port opening wasn't an option and was told that there are very few intakes available. I said "then why don't you make one?"
I was then told that the porters and builders are opening them up. It was just the non racers that don't!
Food for thought....
I guess I will run the Super Victor and an 1150 Dominator cause I have them, but see what I run into at the swap meets!
I would like to hear from someone that has run the Max Wedge stuff though.
As our car freak amigo Jay Leno said: "I am lucky enough to have F**k it money so if I see something I want but don't need, I can say F**k it, and buy it cause it's cool."
TIMINATOR
I haven't ever done a back to back comparison myself. I remember reading some dyno results somewhere that a properly tuned and modified with the inner wall dams on a cross ram was 40-50 horsepower over a stock/oem single 4 bbl intake and carb set up. However, on a bigger 512 cubes the dominator will probably be another 40-50 horsepower more than the cross rams. For the coolness factor I would certainly go with a cross ram also, but unless you were trying to meet some sort NSS or nostalgia class rules. The 4500 Dominator and single plane manifold would be the way to go for that every horsepower needed if that is what you are looking for rather than looks.
I did go from my factory Hemi cross ram to my current high rise tunnel ram with also a larger camshaft change on my 528 and it did pick up 238 horsepower.
Now I think that's impressive! Big block bigger numbers! Where did the HP show up, on top of the power band?
Yes, the tunnel ram picks up most at higher RPM and had a higher and longer torque curve.
Crossrams are cool and not often seen. Tunnel rams will make the most power and torque and the would be capable of feeding a 512.
Intake comparison Hot Rod did on a 383 a couple of decades ago.
For a 383 the M1 is probably good, but for @TIMINATOR and his modified heads and 512 cubic inches, the 440 M1 would probably not be so great. A tunnel ram might just be the ticket, no?
But I also see the appeal of the crossram.
M1 seem to be pretty good intakes. Of course finding them isn't easy and they tend to be pretty pricey when you do.
I'm thinking for a 512, go tunnel ram. 512 is a lot of inches and there is no sense in pinching it with airflow. While not as cool as an under hood cross ram, they are still pretty darn cool looking.
I was wondering that maybe filling the outside corners inside the plenum areas would help airflow and throttle response.
I have partially filled tunnelram plenums and achieved better "street manners", I.E. midrange and throttle response.
I have done extensive mods to the chebbie 1982-1984 stock crossram intakes with remarkable results, done properly they outrun the P.O.S. Tuned port intakes.
But without a removable top the MOPAR Max Wedge intake modding inside would be a task in itself.
Did Edelbrock make a street crossram for the 440s like for the big and smallblock chebbies?
TIMINATOR
I have always liked the M1 and TM7 intakes any have run several on my street/Strip builds.
