73 barracuda parts identification help needed...
Flathead31coupe
Indianapolis
Does anyone know what these parts go to?Thanks in advace..
The two parts on the left and right look like a part sometimes referred to as the Front Fender to Cowl Brackets.
Refer to: MM1108A - 1970-74 Challanger, Barracuda, Cuda; Inner Front Fender To Cowl Bracket; RH Passenger Side; EDP Coated
The center bracket looks like a K-member support piece, that attaches centerline of car from the base of the radiator support to the front of the K-member (on which the engine mounts)
If I win the contest, I choose item #4722 from the awards booklet, an extra-large NY-style pizza with uncured pepperoni and the 2x 128oz containers of Amish Lager.
Would you have a picture of where these go on the cowl to the fender thanks
Do you have a picture possible of how these are mounted... Thanks
Here is an excerpt from the '71 Body manual for a Barracuda. It shows a stud at this location, not a bolt.
I\n Noticed that the diagram shows Fender bolts in the tops of the fenders, except for the bottom of the Fender by the door has studs, mine seems to have studs on top of the Fender and boats at the bottom of the Fender by the door any clues. Thanks
To my knowledge only the TA’s and AAR’s had studs on the top.
I will look at the ‘73 body manual I found on line later when I am at my desktop.
I don't do fakebook but found this post where you can see the studs and nuts that go at the bottom of the fenders and at the cowl bracket.
