Flathead31coupe
Does anyone know what these parts go to?Thanks in advace..
SorryThe picture didn't load, it's there nowNot as pictured.
ThanksThe two parts on the left and right look like a part sometimes referred to as the Front Fender to Cowl Brackets.
Refer to: MM1108A - 1970-74 Challanger, Barracuda, Cuda; Inner Front Fender To Cowl Bracket; RH Passenger Side; EDP Coated
The center bracket looks like a K-member support piece, that attaches centerline of car from the base of the radiator support to the front of the K-member (on which the engine mounts)
If I win the contest, I choose item #4722 from the awards booklet, an extra-large NY-style pizza with uncured pepperoni and the 2x 128oz containers of Amish Lager.
Would you have a picture of where these go on the cowl to the fender thanks
Do you have a picture possible of how these are mounted... Thanks
Thank you.
Does it attach to anything?Or is it just a brace or what?Thanks
It bolts to the side of the cowl.Does it attach to anything?Or is it just a brace or what?Thanks
ThanksIt bolts to the side of the cowl.
Then there is an upward vertical bolt to secure the fender to it.
