Does anyone know what size the screw that goes thru the signal switch and into the Signal Arm ? It seems it went into the Twilight Zone !!
Thanks man I appreciate the help. I had no idea how long it was and the thread.The screw to fasten the switch assembly to the turn signal lever has 8-32 threads. The screw is ~1-7/16" long from the flanged hex head to the tip. The screw has a pilot tip to help align in the threaded portion of the lever. The threaded portion of the screw, minus the tip, is ~1-5/16". The hex head is 1/4" and also has a slot for a flat blade screwdriver.
The following images show the screw:
