Header leak or lifter , tappet
7DCUDA383A
60 Miles West of STL
This sound is back , just had my distributor crap out on me , luckily it wasn't my chain . IT sounds like a header leak and it sounds like lifter or tapped type issue.
Hard to really tell in the video but if it is a header leak, you should see some black from the area of the leak. Maybe a leak at the collector gasket?
Did you try the long screwdriver to the ear trick to try and pin point the sound or an automotive stethoscope?
I'm a change oil and brake pads mechanic , I have learned a lot working on this car but the technical stuff still floats by the brain cells I have left , I just did order a stethoscope that will be here tomorrow and I also ordered Remflex header gaskets and collector gaskets , the car came with studs for headers , all nuts seem tight but something could of been loose to cause a leak.
Take a length of vacuum hose, wrap some malleable wire around is so that you can shape it as you want. Put one end to your ear as you put the other end around the flange with the engine idling. When you get to a leak, you will sure know it.
The wire needs to be a little tight on the hose to retain the shape that you want, but the loops only need to be every inch or two and as small a wire as will hold the shape you want.
Always works for me. :thumbsup:
When I had headers on my car before I throw them away, I had a header leak that I noticed at night. You can see the flames popping out against the head and the flange.
Definitely sounds like an exhaust leak because it tends to go away when you revved the engine. A lifter or rod bearing would just get faster. At night, you should be able to see flames like @Mopar Nut mentioned if you can get at the right angle - might have to crawl under the car. And the only way I'd crawl under a running car is on a lift or jack stands so all four wheels are off the ground.
Stethoscope should pin point the leak for you.
I hope it is , some people on another group said lifter etc. but most people said header leak , I'm putting on Remflex gaskets and take my time with it .
Forth of July special. There is a way to find a small Natural gas leak. Use a match. Same for a vacuum leak on a motor use an accelerant. Gas or other. Find if it's exhaust leak. Use a torch to see if the flame is blown out. Or use an object to see the exhaust leak. Hint don't use you finger cardboard or other.
