JoeNY
Well, it looks like I'm going to have to buy a dash harness. Anyone have suggestions between the Classic Industries $679 or the Year One $799 choices?
I wouldn't think so. You will have the same inherent problems. In short no pun intended. the wires for the load (Alternator feed)and battery ( for stating and changing battery) are one of the problems. An other common one is the headlight load on the wiring. A headlight relay circuit is a fix. the last but not least is the fan load for heater or AC. The fix is a relay circuit under hood feed or a AUX fuse box to feed other accessories. Feed VIA foot washer pump gourmet. Here again feed needs to come from the alternator feed some how. That leads to an Alternator feed bypass.it looks like I'm going to have to buy a dash harness.
Bulkhead and amp meter bypass.
Here are some examples of what can be done. Not saying what is correct for your application. Connecting to the starter relay circuit is eclectically the same in this manner. BUT the gauge of wire from the relay to the battery is not adequate. That's why it should be connected to the starter feed or directly to the battery. Also a headlight relay circuit would be advisable. The main point of it is that the load is electrically connected to the alternator. That being said. Splice one also has to be feed from the alternator. The alternator never was a on a fusible link that feed splice one. It would be advisable to place one there. As it was said before the the diodes would or might blow before any damage . But why take a chance. View attachment 141943
View attachment 141942View attachment 141947View attachment 141948View attachment 141949
That is all it is. Clean and treat as mentioned. Each load side fuse holder can be removed and cleaned.that surface rust at the fuse terminals is easily treated with many OTC rust products.
