unclejesse
Anyone have a list of what accessories could be going into these 3 port connectors? Understand that all models wouldn't have had all options. The wiring diagrams always end at those. Then show up at random other spots.
As indicated the 3-way female bullet taps are for optional accessories not present on all vehicles. Color coded, yellow on a tan wire is from a fuse in the fuse box on the accessory bus, options vary, but if A/C equipped, the A/C dash harness connects there to provide power to the compressor clutch. Other taps are, Red for unswitched fused power, orange for the dash illumination circuit and on some other platforms, a black 3-way on yellow wires tapping into the door pin switch circuit.Anyone have a list of what accessories could be going into these 3 port connectors? Understand that all models wouldn't have had all options. The wiring diagrams always end at those. Then show up at random other spots.
My two yellow 3-way female accessory connections come off the fuse box & do not connect to anything.As indicated the 3-way female bullet taps are for optional accessories not present on all vehicles. Color coded, yellow on a tan wire is from a fuse in the fuse box on the accessory bus, options vary, but if A/C equipped, the A/C dash harness connects there to provide power to the compressor clutch. Other taps are, Red for unswitched fused power, orange for the dash illumination circuit and on some other platforms, a black 3-way on yellow wires tapping into the door pin switch circuit.
