F8RT
Put a bit of paint on the dash area to check the colour , it's getting close
I aligned the rear of the door to the face of the rear quarter and by adjusting the fore and aft door hinges on the pillar and this allowed me to raise the door slightly with a flloor jack under the main part of the door and not using the edge so no damage.Then i backed off the hinges on the door to get the edges be it in or out to line up, this was done slowly till i was happy with the rear door contour. bolted up the front fender with the new front amd valance and adjusted the fender with shims where the fender bolts to the rocker, lots of mucking around here using hammer and dolly . Just do a bit then keep checking the contour and gap on the front door to the rear of the fender.Door looks nice, what the procedure/steps to get it aligned?
I concur with the floor jack method. Also when adjusting I added some weights inside the empty door shell to account for the weight of the glass and mechanism and door panel as this may cause the door to sag slightly upon reassembly.I aligned the rear of the door to the face of the rear quarter and by adjusting the fore and aft door hinges on the pillar and this allowed me to raise the door slightly with a flloor jack under the main part of the door and not using the edge so no damage.Then i backed off the hinges on the door to get the edges be it in or out to line up, this was done slowly till i was happy with the rear door contour. bolted up the front fender with the new front amd valance and adjusted the fender with shims where the fender bolts to the rocker, lots of mucking around here using hammer and dolly . Just do a bit then keep checking the contour and gap on the front door to the rear of the fender.
I have heard of using a length of chain that is around 50 lbs to simulate the glass and all the hardware if the door shell is empty.I concur with the floor jack method. Also when adjusting I added some weights inside the empty door shell to account for the weight of the glass and mechanism and door panel as this may cause the door to sag slightly upon reassembly.
