1971 Challenger
Hey folks,
So I have a 71 Challenger, 440 BB, and unfortunately not a lot of information on the engine. I've been chasing an overheating issue since I got the car about 2 years ago. I did upgrade to EFI a while back but already had the problem. Recently, after a radiator/fan upgrade, I was on the pedal at high RPM on country roads and it climbed up to ~235, albeit it had sat beforehand in the sun for several hours. It moves up slower now overall but still climbs. Majority is at speed. I've read most of the posts so let me summarize where I'm at in no particular order without going over the entire past:
* Put in 26" Cold Case Radiator 2 row RAD-MOP754A
* 15 Inch 3,300 CFM Flex-A-Lite Black Magic Xtreme Series Electric Fan FLX-104367 8 blades with shroud
* Running 180 OEM thermostat; high flows failed and seem unreliable; fan come on at 190 as set in Sniper II.
* Running 15 degrees timing
* New hoses; none collapsed during operation
* EFI A/F ratio double-checked
* Inlet/outlet hoses and radiator core temperatures tested with IR gun and probe; They agree with my dash gauge.
* Fan has its own line to the battery; Alternator is at least 60A and is working fine.
* Serpentine pulley is fine.
* No fan on the condenser.
* 50/50 mixture. Coolant looks fine and at the proper level.
So I'm down to the water pump, I believe? Might I be getting cavitation? Not enough dwell time? Am I supposed to have a high flow water pump or standard? Is there any way to tell without pulling it? Any way to diagnose this component?
Let me know if I missed any troubleshooting aspects.
