jimkov
I just changed the oil in my 71 Challenegr RT for the first time. 383 with a mild cam, six pack, and a 4 speed. I contacted the past few previous owners but the paperwork on the engine build from 2018 by Mopar Madness in Colorado was lost and I reached out to the shop but never received the build sheet after a few requests.
I went with Driven HR-6 10W-40 since I'm in West Texas and there are many days over 100 F.
The issue I am having is a sputtering/clunking noise in hard acceleration. It sounds like the noise when you are about to stall the engine at low speeds. It's does not seem like a carb bog. The acceleration is very close to ideal. I'm also having issues with the engine continuing to run after turning the car off.
Drained 4.2L of oil and 4.4L filled it just below the full line.
I changed the PCV valve. The old one had a thin costing of the new oil in it and the carb port it was attached to. I've played with the setting in the car and made it a lot worse. I got it back to the settings I had prior to the oil change but the sputtering/clunking and the enginer runoff on turning the car off still persists.
I'm thinking maybe an internally sticking accelerator pump, leaking piston rings, improper oil grade for my setup, possible over filling due to an after market dipstick. If anyone has any suggestions please share to help guide my next action.
