Parking Brake Not Working
mopar70
Canada B.C
I need help with my parking brake the pedal goes down very easily and now it just gets stuck and doesn't come back up. It doesn't engage the brakes and now the lever gets stuck. Please help I need to fix this to insure the car.
7071 challenger
Sounds to me that there might be a cable broken and nothing, (except the pedal) is moving. Make shure you have a cable hooked to the pedal. If you do, check if the cable is moving when you depress the pedal. (you can have somebody depress the pedal while you look underneath for any movement). If the cables are moving, the next step is to open the rear drums and check if the brace between the two shows are installed. If they are not there, the shoes won' t engage the drum. Let us know the results.
Robert
Moparparts
i have some good used cables if you need them PM me
often the cables will sieze , often you can get them to move enough to get the brakes on but the springs cannot pull the cables back
mopar70
Canada B.C
The cable gets pulled that is attached to the pedal but when I opened up the drum nothing moves. Everything seems to be there and the spring on the handle keeps coming forward the little rubber piece broke off.
7071 challenger
because you user name has "70" in it, I assume that this is the year of your car. If so, you will have 3 cables, one from the pedal, and you will have a bracket, on the driver side, a little ahead of the differential housing, that hooks the 2 other cables, (one for each wheel). When you depress the pedal, the front cable should pull the 2 other cables. Because you told us that the pedal moves very freely, I suspect the front cable being broken. It might move close to the pedal, but maybe not at the other end. Again, i suggest that, you crawl underneath and have somebody depress the pedal and make shure that ALL 3 cables are moving. If your car is a 1970, the cable that goes to the passenger wheel is very long and might be seized. Let us know...
Robert
mopar70
Canada B.C
On the pedal assembly the spring keeps coming forward through the hole where could I find that rubber piece to put in there so it keeps the spring back but lets the handle move.
Mine does the same thing , I need to find a plastic busing I can drill through the center & split to go around the shaft & slide in on the spring side to hold the spring , easy fix .
Kd8mff
I'm trying to find a routing diagram for the e brake on a 74 Cuda. Any help would be appreciated.
