70 cuda upper radiator hose help needed
I have a 70 cuda with a hemi and shaker assembly, the car has a 27" wide "just be cool" cross flow radiator, the offset from the thermostat nipple to the radiator inlet is about 10 1/4", I have a factory, hemi, 26" radiator "shaker" hose #3462184 that is offset about 8", this stretches and distorts the hose too much, has anyone located a hose that will fit better and look correct?
ramenth
Beaver Dams, NY
Have you contacted the manufacturer of the radiator to see if they have any suggestions?
Welcome aboard, by the way.
Yes, I was told to go to the parts store and search thru all the hoses and see what I could "make work", BS man they should have a hose # on file that fits the application, a big block using their radiator.
That is what I have done in the past is find a hose with similar bends & diameter to fit , sucks they did not do the homework for their part
