Resto-mod Challenger
Blown71duster
Got the battery cables ran up front to the blue sea fuse box , this gives it heavy duty protection fuses for alternator, relays etc. Also gives it a ground buss to the dash area.Ran 1/0 battery and ground cables from battery in trunk up to the starter.
Penfighter
South Florida
attention to details=a great ride
Put the instrument cluster and steering column in to run the wiring .
[FONT=&quot]I don’t recognize the battery mount. Whose did you use?[/FONT]
[FONT=&quot]Where did you get the header collector heat deflector?[/FONT]
[FONT=&quot]Similarly, whose gauges did you use to mount in the stock dash panel openings?[/FONT]
[FONT=&quot]Looks like you are using quality pieces and paying attention to details to make a great ride better. Yep, somebody has been doing a lot of research. Keep it up.[/FONT]
Blown71duster
[FONT="]I don’t recognize the battery mount. Whose did you use?[/FONT]
[FONT="]Where did you get the header collector heat deflector?[/FONT]
[FONT="]Similarly, whose gauges did you use to mount in the stock dash panel openings?[/FONT]
[FONT="]Looks like you are using quality pieces and paying attention to details to make a great ride better. Yep, somebody has been doing a lot of research. Keep it up.[/FONT]
Thanks,
The battery Tray is made by a place called Billet proof design , it is made for the 34/78 group Optima battery.
The header heat deflector I made from aluminum with a sheet metal brake and tig welded brackets to bolt them on.
The gauges are Auto meter pro comp and are mounted in an xv motorsports dash insert
Blown71duster
Started running wires today to the fuse panel. Engine will turn over now and have power to the Hotwire harness and ECM11924742_10153455949863654_8167939665408889517_n.jpg
Blown71duster
Test fitting the new tail lights and bezels. Also got a Fab 8 3/4 from Moser and installed the RMS street Lynx rear suspension in it
Blown71duster
Using Magnum Force Transformer suspension . Getting ready to send it out for powder coating. Really impressed with the K-frame and control arms how beefy everything is , should hold up well on the street. Putting Wilwood brakes front and back.
Blown71duster
Got the Front and rear suspension back from powder coating . Will be working on installing the front and bolting up to the Hemi engine.
Penfighter
South Florida
Getting close now to wearing a constant smile, eh? Doing quality work and using quality pieces always equals fun times with confidence.
Any particular reason why you chose a Jones Racing power steering pump?
Blown71duster
Got the TTI exhaust all on. Had to re-weld some things, but fits really well with the RMS rear suspension .Factory R/T split tips
Blown71duster
Working on installing a Vintage Air ac unit. Mounting the Drier inside , made a custom bracket to mount it to the box with a Hard line. Using Braided stainless ac lines from vintage air .
JpRngr
Have you mocked up wheels and tires? I've got the MagnumForce front end also, and curious your front wheel tire combo.
Corey
JpRngr
Also curious, did the a/c compressor come with the VA set-up, or is it a stock Dodge unit? Doesn't look like there's a whole lot of room where it mounts in relation to the MF motor mount on mine.
340challconvert
Parsippany, NJ
Wow
Great work on the sheetmetal and bodywork!
Impressive high tech resto mod build!
Cool use of a modern drivetrain and electronic upgrades!
Blown71duster
Have not got the wheels and tires for it yet. I will be using a percy wheel fitment gauge to order the correct offset.
The ac compressor is stock for the Hemi. I used adapters on it to adapt to the vintage air fittings.
Plenty of clearance to the MF frame. Had a stock K frame to begin with , which required trimming to get the compressor to fit it.
Dillon
Im thinking of putting a new hemi in my 70 challenger what yall think
