How do I installfront eye leaf spring bushings
jimclo2002
atco,nj
Do I need heat the end of the leaf spring to open it up some???
Any help
Don't heat the spring eye. The bushing needs to be pressed in. Easier to do with the spring off the car.
jimclo2002
atco,nj
i dont know how this bushing would go in this leaf spring eyes. bushing looks to big. Plus it has a metal band around the bushing.
If you have the correct bushing it will press in. I just had my bushings with the steel sleeve pressed in recently. No problem. The spring eye will actually open up very slightly.
jimclo2002
atco,nj
1970 challenger leaf spring eye bushoing install
Mopar Lee
Do you have the part number for the leaf spring eye bushings?
Jim
Daves69
ChiWest
If you don't have a press maybe you could pull them in with a threaded rod setup??
Jim: I purchased mine from Amazon. They were ACDelco 45G17012 Professional Grade. $15 ea.
Mopar Lee
Jim
